schardein Posted September 1, 2017 Share Posted September 1, 2017 I am replacing the entire AC system on my MJ (except evaporator). After I removed the condenser, I was surprised to see I have a single core radiator. It's the original. The tanks have the place for the second core, but it's not there. Mine is an original 4.0/auto/AC/2wd. Mopar part # 52004917. Is this common? I thought a 4.0 would have a 2 core. I have a spare rad out of a later XJ, found it in a junkyard, looked like it had been installed and never even filled up. It will be going in. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 1, 2017 Share Posted September 1, 2017 That's the base HO radiator w/o the max cooling option. Same one I had originally in mine. Link to comment Share on other sites More sharing options...
schardein Posted September 1, 2017 Author Share Posted September 1, 2017 OK, thanks Don. Did the max cooling option add anything else, besides a two core radiator? I already had an electric fan, because I had AC, I suppose? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 1, 2017 Share Posted September 1, 2017 AFAIK, for the HOs the Max Cooling option came standard with the Tow package. The Max Cooling option also had the factory transmission cooler if equipped with the AW4. You could also mix and match any options you wanted when ordering, so anything was possible. My base model 91 also came with factory A/C and had the aux fan. Link to comment Share on other sites More sharing options...
schardein Posted September 1, 2017 Author Share Posted September 1, 2017 OK, thank you again. I've pulled two oem trans coolers to eventually use on my XJ and MJ, but never understood why some XJs had it and others didn't. Being a part of a towing package makes perfect sense. Link to comment Share on other sites More sharing options...
Minuit Posted September 1, 2017 Share Posted September 1, 2017 Yep, I had a dinky tiny radiator too. My truck was totally optionless except for the 4.0, A/C and automatic trans. Link to comment Share on other sites More sharing options...
schardein Posted September 2, 2017 Author Share Posted September 2, 2017 9 hours ago, Minuit said: Yep, I had a dinky tiny radiator too. My truck was totally optionless except for the 4.0, A/C and automatic trans. That sounds like mine, lol. It didn't even have a radio. Link to comment Share on other sites More sharing options...
Minuit Posted September 2, 2017 Share Posted September 2, 2017 Neither did mine - no speakers in the doors and the build sheet had the "radio delete" option on it. How far we've come... Link to comment Share on other sites More sharing options...
