Suddenly dies
Hi guys
So, my truck (-88 4L aut) has now on two occations suddenly died. Its like if you turn it off, but while driving. Thankfully it has been while coming to a stop on small streets. I have just stopped, it fires right up if I just turn the key again. Maybe it cranks for a few more seconds when turning the key again.
I have noticed that it seems to "cough" a bit on the cranking lately, not the engine but the starter I think.
Could these issues be related?
I was thinking the starter is going out, but the EMP syndrome seems more of a bad connection issue somewhere.
Anyone got any ideas as to where to start looking?
Can you change the coal on the starter? No idea if it is still stock though.
Cheers
Mathias
Skickat från min iPhone med Tapatalk
Yep, the CPS needs to be ruled out first when anything like this happens.
If by "coal" do you mean the brushes in the motor? Yes you can, and the starters are fairly easy to rebuild. In the US at least the parts to do so are inexpensive. Would be an excellent time to clean the internal workings as they get oil and gunk inside of them over time.
Thanks Cruiser, will do. Do you think the "cough" from what I believe is the starter might be bad ground on the starter itself? Seems like its hesitating sometimes. Battery is 6 months, alternator is good. I got the Nickintimes REM plugged in so I know its charging good.
