Going nuts with a wrench buster
Having a hell of a time getting the large hub nut off. Have tried PBR, busted my brake-over bar twisted a monkey wrench, tried using heat with a hand torch using Bernzomatic MAP/PRO GAS. Even heated it up for 15min and threw cold water on it. That would give it a rapid expiation and contraction rate and possibly break it free. It was a no go. Any ideas would be appreciated. The truck has 136,000 on it and the hud is grinding. Thanks
Heated it up again and threw cold water on it. Put the other break-bar on it. Went ahead turned it the opposite way to tighten and l herd a pop. Put the impact on it and alternated with reverse and forward for about 45 seconds. It finally broke lose and spun off. Wow what a relief. Going to apply some anti-seize on this puppy. Hope the other sides not like this ordeal. Thanks for the input. I
Anti-seize is good. Just remember that anti-seize qualifies as a thread lubricant, so reduce specified torque by approximately 20 percent.
