*MORE* MJ/XJ Parts in Des Moines, IA
Dzimm
I am doing a purge of my extra parts laying around. Here are the links to the craigslist ads. The prices are listed in the ad. Make sure to let me know if you saw the ad here and we can work out a better deal. Shipping will be negotiated during sale unless otherwise noted.
Lower Control Arms
http://desmoines.craigslist.org/pts/6257553921.html
MJ Leaf Springs
*SOLD TO Johnj92131*
4.0L Engine Block
http://desmoines.craigslist.org/pts/6257580831.html
Coil Springs
http://desmoines.craigslist.org/pts/6257646304.html
MJ Fuel Line
*SOLD*
97+ XJ Fuel Tank and Pump
http://desmoines.craigslist.org/pts/6257655482.html
MJ Dana 35
*SOLD*
EDIT:MORE PARTS ADDED.
- MJ/XJ hood with a 2 small, mostly unnoticeable dents. Peeling white spray paint over factory black (no rust). $50
- 97+ fenders. Spray painted white. 1 noticeable dent on both, factory antenna and wire still attached. $25 each. 6a160b44c5ad2aa320f13de218b79aa6.jpg8c946d680eefa510a023635671d22ee4.jpg
- 97+ front clip. Spray painted white but peeling, has one of the plastic trim pieces around the lights, has the grill insert. Needs new amber lenses and has a few small cracks. $25.
- Factory 97+ white bumper with white end caps and white under bumper trim thing. Also has the license plate bracket. Plastic is all in good shape, the bumper has some surface rust on the front. $100.
- Brake booster and master from 90 Comanche. $35
- Gray Tilt and Column shift steering column from 90 MJ. This is the whole thing, from the steering wheel all the way to the power steering pump. It does have the common loose inner bolts so it wiggles. All intact and in good shape. $100
- MJ load sensor bracket for the diff cover. Has surface rust. $10 shipped.
- Wiper motor and linkage from 90 MJ. $25
- Cowl grill cover thing. Spray painted white and has a couple small cracks. Has the black mesh but not the sprayer nozzles. $5
- 97+ cruse control unit/cable in good shape. $20
- Gray MJ driver and passenger kick panels. Great shape $25 for the pair.
- MJ brake pedal, bracket, and brake light switch. $30
- MJ license plate light harness. 1 wire needs repaired right where it enters the light plug. $20 shipped.
- Factory airbox with hose to the throttle body from a 98 XJ. $25.
- Hose from factory airbox to throttle body(pictured above). Free You pay shipping.
- 2 battery sensors for 97+ XJ. $15 shipped each.
- Factory battery cables from 90 MJ. (battery to fender, battery to block, battery to PDC, and alternator to PDC, with good battery connectors). $20 shipped.
- 97+ airbag module and bracket. $25.
- MJ body wiring harness. Has the steering column ribbon style connector on it and it runs along the drivers door. All good but has 2 wires that are cut that I think are the speaker wires. $15.
- These smaller things are name your price. As long as shipping is covered I'm fine with whatever they go for.
Rear door checks from an XJ, factory airbox inlet cover, front sway bar mount/bushing in great shape, under dash passenger kick cover thing
Older style MJ/XJ door seals
97+ XJ center console vent tube
For obvious reasons, some of this stuff cannot be shipped.
Wish you were closer. Those leafs would be nice
Someone from here is interested in them and passing through my area beginning of next week to maybe pick them up.
I run into this situation all the time, I'm not in a good area for Comanches. All of them around here are gone so nobody has or needs parts for them.. And all the parts I need or want are halfway across the country.
That is me.  Planning to be in Missouri for the eclipse on Monday, so plan is to drive thru Des Moines on the way to or from the eclipse.
Archived
