Motorhead X Posted July 24, 2017 Share Posted July 24, 2017 My horn is not working and I am hoping someone can make a solid identification of the relay. A lot of earlier posts are missing images due to Photobucket. Here is the one I think it is, the one on the right. I tried replacing it and didn't make any difference, but I need to make sure I have it correctly identified. This is on a '91 4.0 So far I have tested the horn by jumping it to the battery and it works fine. It does not seem to be getting power otherwise. I have also cleaned the round spring and cap under the steering wheel cover. The relay is not clicking when I press the horn. Fuse is good. May have to dig deeper in the steering column. Thanks. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted July 24, 2017 Share Posted July 24, 2017 Not sure about the 91 on the 85 the horn relay was by the fuse box and the seatbelt chime. When I got it the electrics were a mess from a clutch master leak, the horn didn't work. Had to replace the horns, then the relay, when I did that I could touch a wire in the steering wheel and get the horn. Eventually I replaced the steering wheel with a better one with a easier to fix horn button. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted July 24, 2017 Share Posted July 24, 2017 This link has something about fixing the horn on a 91 XJ https://www.cherokeeforum.com/f2/horn-help-56024/ Looks like that matches the description of where they relay is located in the 91. To the right of the steering column on the lower instrument panel trim. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 24, 2017 Share Posted July 24, 2017 Yes, one of those two under-dash relays is the horn relay on a 91. To test swap the two relays and see if the horn works. If it still doesn't, it's most likely an open ground circuit in the column. Link to comment Share on other sites More sharing options...
Motorhead X Posted July 24, 2017 Author Share Posted July 24, 2017 :cheers: Link to comment Share on other sites More sharing options...
Ochoa88 Posted March 24, 2021 Share Posted March 24, 2021 I have the same problem. but I'm missing both (boxes) relays. Anyone know what the other is for? Link to comment Share on other sites More sharing options...
Ωhm Posted March 25, 2021 Share Posted March 25, 2021 2 hours ago, Ochoa88 said: Anyone know what the other is for? Radio/LCD clock illumination relay Link to comment Share on other sites More sharing options...
Ochoa88 Posted March 25, 2021 Share Posted March 25, 2021 Thank you. Link to comment Share on other sites More sharing options...
