Kyleinreallife Posted July 7, 2017 Posted July 7, 2017 So I have an 87 sportruck with the 4banger. I want to put the straight 6 in it. What's the best route to go? Any advice appreciated!! Sent from my iPhone using Tapatalk
Crash Posted July 7, 2017 Posted July 7, 2017 2 or 4wd? Other than that, buy a running driving XJ/MJ and swap everything necessary. Rear driveshaft will not be plug n pray if you get an XJ donor
MuddFoot Posted July 8, 2017 Posted July 8, 2017 I swapped to a 95 only issue I had was the fuel tank. Everything else kinda bolted in. I ended up using a 22 gal 96 Dakota tank and sender. Switched to a newer returnless fuel rail. Sent from my Z981 using Tapatalk
