Preventing bedside rust by adding drain holes.
So I recently patched a hole in the bedside of my 88. While I had the wheelwell open I noticed how dirt gathers in the top of the pinch seam where there's no drainhole. The only thing like a drainhole I noticed was about 3" farther up the wheelwell.
I'm thinking of drilling 2 or 3 small holes the size of a small rubber body plug/cap just inside of the pinch seam to serve as drain holes.
Any opinions?
Any opinions?
Do it - can't hurt. BTW, where is Waste Valley? Sounds nice ;)
The way I figure it, it's not the water that's the problem, but rather the dust and dirt that collects on that ledge and retains the moisture. Cleaning it once in a while should do the trick. :cheers:
