Minuit Posted May 8, 2017 Posted May 8, 2017 I already grabbed one for myself, might as well share. I mistyped a part number for a radio and found a number of NOS power window/lock switch panels with switches on eBay. These are what you want to add power windows and locks to a Comanche (or 2-door XJ) Sadly, no door handle is included but you can swap over your old one. http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.X56007219.TRS0&_nkw=56007219&_sacat=0
Siopposition Posted May 8, 2017 Posted May 8, 2017 Purchased one. I have the pass side already bit the truck I pulled it from was missing the drivers side. Thank you!!! Sent from my SAMSUNG-SM-G891A using Tapatalk
Streetglide409 Posted May 8, 2017 Posted May 8, 2017 Thanks for sharing! Sent from my iPhone using Tapatalk
HOrnbrod Posted May 8, 2017 Posted May 8, 2017 I put these in originally but didn't like them. Swapped them out for the older chrome ones. For some reason they fit my rig better. :yes:
Minuit Posted May 8, 2017 Author Posted May 8, 2017 I put these in originally but didn't like them. Swapped them out for the older chrome ones. For some reason they fit my rig better. :yes: I wonder why that could be? :D
Minuit Posted May 8, 2017 Author Posted May 8, 2017 The P/N for the other side is 56007216. Several NOS results for that one too :)
Tex06 Posted May 22, 2017 Posted May 22, 2017 Is the wiring already in place for this swap? (I know I should do a search but everyone is already here!)
HOrnbrod Posted May 22, 2017 Posted May 22, 2017 Is the wiring already in place for this swap? (I know I should do a search but everyone is already here!) No. You need the wiring from a donor or you can make your own harness. It's not difficult.
Minuit Posted May 23, 2017 Author Posted May 23, 2017 The wiring from a 91 or 92 XJ with power options is almost totally independent from anything else and makes a pretty easy "lay in" swap. You just need to supply power and ground to the harness in one location, plug in a couple of fusebox taps, and you're good. If it's a 4dr XJ then you need to swap two wires on the driver side switch panel plug. Pretty easy swap, very worthwhile IMO. Once you've done that, keyless entry is just a step away too. I got mine installed the other day. They look nice.
HOrnbrod Posted May 23, 2017 Posted May 23, 2017 I put these in originally but didn't like them. Swapped them out for the older chrome ones. For some reason they fit my rig better. :yes: I wonder why that could be? :D The biggest reason was so that the chrome window switch bezel would match the armrest chrome bezels. The all-blacks just looked out of place to me. And as everyone knows, the more chrome the better. :thumbsup:
