JeepFanactic Posted April 18, 2017 Posted April 18, 2017 In the middle of installing the front lift for my 87 MJ. I installed the 3.5 in coil springs and the adjustable control arms. I have not installed the track bar yet but it looks like the coil is hitting the bump stop on top. How can you ensure the control arms are the right length. Will everything straughten out when I get the track bar in? Just looks like the coil springs are not sitting straight. Any help would be appreciated. Thanks
JeepFanactic Posted April 18, 2017 Author Posted April 18, 2017 do you have adjustable lower control arms? Yes I do. I adjusted them to the measurements I found on here. How do you make sure that the lengths are right? Is there a way to check the measurements?
WyoCherokee Posted April 19, 2017 Posted April 19, 2017 When you lower the rig down, it will straighten out. Due to the radius arc motion of the arms, at full droop, the axle will swing backwards when hung fully suspended.
