cjomanche Posted April 18, 2017 Posted April 18, 2017 My transfer case leaks, probably needs an overhaul. Can someone recommend a good quality kit?
DirtyComanche Posted April 18, 2017 Posted April 18, 2017 Not really. SKF sells a seal and bearing kit, and there would be nothing wrong with it, but you need more than that. The chain is the big wear part, IMHO. Alloy USA sells one, along with numerous shady eBay sellers, I don't know what the quality is like, and would suggest trying to source an OEM NP/NV chain instead. If you can afford the downtime I'd take it apart and see how things are first. Often the bearings are all fine and a tighter chain and an input and two output seals is all it needs.
