I have a 1986 with the 2.5 TBi pump in the tank. Got bad wiring on top of hanger assy. Leaking gas can't seal.  Looks like no replacement available for that year.  1987 4.0 is avaialble but I doubt that it will work. Can I get some past success stories.  Thanks
Welcome, Kenny D.
Lots of good stuff here.  Including this very recent repair of a H.O. 1991 fuel sender unit that will help you out.  Remember, you fuel sender is NLA from Jeep.  So you need to repair what you have.  This repair will be a little different from your sender, but should be an excellent read to follow.
http://comancheclub.com/topic/52339-fuel-sending-unit-repair/
Think it is also in the DIY section.  Be sure to check the DIY index link for all kinds of how to and good projects.
