texasjack Posted March 20, 2017 Share Posted March 20, 2017 Has anyone come up with a method to stop the plastic oil cap from leaking on the plastic 4 cylinder valve cover? I purchased a new cap and it leaks, installed a second gasket it leaks. I was thinking about removing the tabs from the valve cover and using a expandable rubber freeze plug with a wing nut to tightened it. Any ideas will be appreciated. Thank you texasjack Link to comment Share on other sites More sharing options...
Marine1Texas Posted March 20, 2017 Share Posted March 20, 2017 sounds like to much pressure and your breather is clogged. Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 20, 2017 Share Posted March 20, 2017 You likely have blow-by, crankcase pressure, you'll never get it to stop leaking. I suggest an aluminum cover from a 90s Wrangler. There's a 90% chance you'll destroy the cover taking it off, they get brittle with age. So, the chance of you altering/modifying without damaging the cover is slim. Plastic is still available, if you want a plastic replacement, I suggest having the new one before you remove the old one. My setup is a little different now but this was the replacement- Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 21, 2017 Share Posted March 21, 2017 Note the absence of the little lugs on the bottom of the cover where the gasket goes, I ground them off, the blue Felpro gaskets fits much better, no leaks. Lugs are shown here- Link to comment Share on other sites More sharing options...
omega_rugal Posted March 21, 2017 Share Posted March 21, 2017 if it doesn`t leak, it`s not a Jeep Link to comment Share on other sites More sharing options...
