dellstopjeep Posted March 11, 2017 Posted March 11, 2017 I am picking up a new jks trackbar new part #ogs125 and trying to figure out the frame side mounting for the johnny joint. They do not offer a trackbar bracket so I am confused whose drop bracket I will need to use with this trackbar. Searched for pics online but can't seem to find the answer to my stupid question.
Hypoid Posted March 11, 2017 Posted March 11, 2017 The instructions say to drill out the factory bracket. http://www.morris4x4center.com/pdf/JKS-OGS126.PDF
90 work truck Posted March 11, 2017 Posted March 11, 2017 The stock ones worked for me Hope this helped
dellstopjeep Posted March 11, 2017 Author Posted March 11, 2017 It did thanks! Sent from my iPhone using Tapatalk
Jeep Driver Posted March 11, 2017 Posted March 11, 2017 I went and got one from a '98XJ, IIRC, the washer would not sit flat and the taper was different for the MJ. The taper is different for the later models and the sleeve fit better on the later bracket. At any rate, I had movement, the '98 solved that problem. Plus, the paired/plated bolts are nice. It's a good TB, I've had mine for better than two years with no issues. Mine will move to the XJ and I'm buying a new one for the MJ. You'll enjoy it.
Jeep Driver Posted March 11, 2017 Posted March 11, 2017 I'll give you a tip. I can't remember exactly........but I used aluminum bar stock, might have been 1/2" x 3/8" x 4". Lay it across the JJ under the bracket, between the two, it acts as a stop and keeps the JJ parallel with the bracket when you go to tighten the jamb nut at the axle end.
64 Cheyenne Posted March 12, 2017 Posted March 12, 2017 I was always under the belief that trackbar style was to be used in a double shear setup, learn sumthin new every day...
dellstopjeep Posted March 13, 2017 Author Posted March 13, 2017 Wait the mj factory trackbar bracket is different than an xj? It's the exact same frame up front and trackbar Sent from my iPhone using Tapatalk
