omega_rugal Posted February 22, 2017 Posted February 22, 2017 today the CPS gave me the middle finger again, started right up in the morning (cold) drove to work, and a few minutes later it won`t start again (hot this time) so kicked it and went to work. after my shift (nigthtime) starts right up again... whata piece of ... at least i was able to get back home... from what i read, this intermitent "no start when hot" syntom says the CPS it`s dying, i had replaced the cooked wires but the sensor itself is done too so it must be replaced... but why is so difficult to reach from above? the cherokee i was going to trade for my mercury sable had a lot fo space, i was able to reach the CPS sensor easily, on my MJ i can barely tocuh it from below, or XJs have a larger notch?
DirtyComanche Posted February 22, 2017 Posted February 22, 2017 It probably has to do more with which transmission you have than anything, and perhaps how the engine is aligned or how bagged out the engine/tranny mounts are. AFAIK the firewalls are all essentially the same (save changes for the steering column and small things) from 87 and on. And yes, a CPS that doesn't work when it warms up is on its way out. But you really need to put a multimeter on it to confirm it. A dying coil can do that too.
mikekaz1 Posted February 22, 2017 Posted February 22, 2017 you should try a WJ 4.0 CPS its basically death.
