dante2 Posted February 19, 2017 Share Posted February 19, 2017 Not sure what it is called but I have the panel that covers the gauge cluster loose but can't pull it out. I tried searching but could not find anything definitive. How do you get it out the way to get to the gauge cluster? If the column would tilt I could safely pull it out I think. Do I need to drop the column to get it out? Any help would be appreciated. Thank you. Link to comment Share on other sites More sharing options...
Keyav8r Posted February 19, 2017 Share Posted February 19, 2017 If you're talking about the trim bezel that extends across the dash to the radio, it's held in place by four screws in the gauge cluster and some tabs that push in near the radio. Once you have the screws out and the tabs loose you just work the top out towards the steering wheel. It will require a little flexing and a good pull to get it out, but it will come out without breaking. Just take your time and you'll get it out. Link to comment Share on other sites More sharing options...
Keyav8r Posted February 19, 2017 Share Posted February 19, 2017 Make sure the small crescent shaped piece that fits below the steering column is removed before you try to pull the bezel. That piece is missing on some MJs. Link to comment Share on other sites More sharing options...
dante2 Posted February 19, 2017 Author Share Posted February 19, 2017 I have the screws and the little piece below the column out. It just doesn't feel like it will come out. Kind of scary flexing 28 year old plastic hoping it doesn't break. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 19, 2017 Share Posted February 19, 2017 I have the screws and the little piece below the column out. It just doesn't feel like it will come out. Kind of scary flexing 28 year old plastic hoping it doesn't break. I have done it on old Jeeps to the tune of 20 plus times. Doesn't break. Lower the steering column if you're skeered. Link to comment Share on other sites More sharing options...
Keyav8r Posted February 19, 2017 Share Posted February 19, 2017 It feels worse putting it back in. First time I did it I thought it was going to break for sure, but it didn't. Link to comment Share on other sites More sharing options...
Minuit Posted February 19, 2017 Share Posted February 19, 2017 Never had one break on me. They're actually pretty strong plastic. You just have to pull on it. I still get nervous every time I squeeze it between the dash pad and column though. Sent from my LG-D850 using Tapatalk Link to comment Share on other sites More sharing options...
dante2 Posted February 19, 2017 Author Share Posted February 19, 2017 Yeah I got it out. Thought sure it broke when it finally let go. Going to be fun putting it back in. Link to comment Share on other sites More sharing options...
dante2 Posted February 21, 2017 Author Share Posted February 21, 2017 Got it all back together and all gauges are working except the volt gauge reads real low. A tip for anyone that is doing this, if you have a column shift put it in gear and the the top cover falls right back into place. A simple step that is not mentioned in any of the write-ups that I looked at. Link to comment Share on other sites More sharing options...
Steve Gregory Posted February 22, 2017 Share Posted February 22, 2017 Try it without a tilt column, real PITA Link to comment Share on other sites More sharing options...
dante2 Posted February 22, 2017 Author Share Posted February 22, 2017 I don't have a tilt column, I think that is why it was so difficult to get out. Link to comment Share on other sites More sharing options...
