What's it doing?
Most parts stores can sell you the fuel pressure regulator, many will even have it in stock.
The vacuum line might be a little harder, but I believe it is available...  You can also make one using generic vacuum elbows and line.
What's it doing?
This is what I was needing to know... the 90 degree rubber boot is dry rotted something fierce...
Sent from my SM-G930P using Tapatalk
That particular vac line comes with the whole front vacuum harness, but like Dirty said...you can just go to NAPA buy a foot of bulk vac line and two elbows...will cost about $3.00.
Note: take the old line and elbows with you tor size...specify that you just want the elbows and a piece of vac line.  if they look it up in the computer you'll end up spending $20+ for the whole front harness
