1j7ft26s7nl121472
Goose_XJ88
1992, Sport truck?
4.0 / AW4 / 2wd / d35 / SWB
Build date: 9/ 91
Current Location: Sacramento California
Status: Just passed smog with close to zeros across the board. Going to be a periodic dd.
Notes: Nothing special, looks to have had a sports bar at one time. Red exterior, gray cloth interior, Bench seat, dummy gauges, column shift, black bumpers front and rear.
Current owner: Plan on keeping it for a while. Going to do an Eliminator Tribute truck with a sports bar. Also have a 4wd AW4, 242, and MJ d44 to swap in. Got the full cluster ready to go in with matching mileage. Going to do a 97+ console with console shifter and buckets of some kind (96 2 door XJ buckets, or WJ buckets. Also plan on dropping it with ZJ coils, XJ shackles, and blocks. I have have a 99 intake waiting to be swapped in as well. Plan on this being an autocross style truck.
Alright, now that I have owned this thing a little longer now, I am a little torn on the bucket seats idea. I like being able to have the dogs lay down on the bench seat but I also like how comfortable the bucket seats in my XJ are.
I am also thinking about keeping the column shift mainly because I finally came across a 4wd shift indicator for a column shift truck. HENS TEETH!
I finally located a HO Header panel and red grill pieces that will be installed along with a replacement hood since the one on it was dented and is hard to open. I really need to get my 99 XJ back together so I can get the Windshield replaced in it and the Comanche at the same time to try and save on install cost. I also picked up a JCR DIY rear bumper for this thing last back Friday but haven't built it yet because other Jeep has higher priority and I don't have a welder yet.
I still plan on doing the 4wd swap, lower it, and install the roll bar at some point but right now it is not high on my priority list as the truck drives just fine as is. Also want to do a re-spray the factory Colorado Red and bedline the bed for protection.
  • 5 months later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA Charcoal
142 Zone 42-Detroit
1AA U.S. Dealer Retail
26C Customer Preferred Package 26C
2TC Customer Preferred Package 2TC
3VN Customer Preferred Discount
ADA Light Group
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCC Dual 730 Amp Maint Free Batteries
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KER
KWR STRIPE/BADGE/MOLDING/COLOR
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Door Armrest Storage Lamp
LDA Underhood Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBC Compact Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
TZH Michelin Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Body Model TL61
Build Date 9/3/91
  • 1 year later...
