Jrwhite3230 Posted February 6, 2017 Share Posted February 6, 2017 I have a 1989 jeep comanche and I'm not getting any fuel at all in my fuel rail/rack I have replaced map sensor fuel pressure regulator fuel throttle position sensor fuel pump relay and fuel pump is all new i have blown out the lines and even replaced the E.C.U and still unable to get consistant fuel to the injecors !? But when i spray ether into the breather it starts and runs smooth but does not stay running i have checked all the connections and yet I'm stumped ? I have also manualy jumped from battery to the pump and it pumps gas into the rail but gthen doesnt start !! maybe because its flooded I'm guessing but thats the only way ive been able to get any kind of fuel pressure to the rail ! but needs to be done through the E.C.U ectt.... I'm needing anyones help who has knowledge of this same problem or simular ! Signed--------> desperatly in love with my comanche :) Link to comment Share on other sites More sharing options...
87MJTIM Posted February 6, 2017 Share Posted February 6, 2017 Try bypassing the ballast resistor. It is located on the driver's side inner fender. Disconnect the two wires from the resistor and connect them together. The resistor is there to reduce the noise of the pump. These parts are known to go bad. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 7, 2017 Share Posted February 7, 2017 And the ground... http://cruiser54.com/?p=249 Link to comment Share on other sites More sharing options...
Jrwhite3230 Posted February 7, 2017 Author Share Posted February 7, 2017 Thanks Tim But yup i did that years ago I bypassed it and just reconnected those two resister wires together i much apreaciate your help though !!:) Link to comment Share on other sites More sharing options...
Jrwhite3230 Posted February 7, 2017 Author Share Posted February 7, 2017 And the ground... http://cruiser54.com/?p=249 Cruiser thanks ole buddy and yepper I'm back and yes I'm alive :) and yes still have that old truck and nope I haven't resolved this issue yet but I'm certainly by process of elimination getting close well at least in my mind !! well that didn't help now did it :) great to see yiou cruiser you where the single very first I met when I joined several years ago I think maybe 09 or so ? anyways yes I'm having a rough time on this fix the pump I can hear running but when I check at the rack there is no pressure at all when I check at the check valve !! won't even take a reading I have replaced all the sensors checked vacuum lines electrical connections even replaced the E.C.U still no go so its back to the ole black board when I turn the key on I hear the pump ingauging then stops normaly when it builds its pressure it does that but when I crank I can barely get it to start just barely but sputters because not enough fuel getting to the injectors / rack I have to use ether to get it to start but doesn't stay running ? maybe the pump even though uits new it still is bad or just not keeping the fuel prime steady consistently Link to comment Share on other sites More sharing options...
cruiser54 Posted February 7, 2017 Share Posted February 7, 2017 If it is an airtex pump I wouldn't be surprised if it is bad. The hose inside the tank can also fail.... Link to comment Share on other sites More sharing options...
Jrwhite3230 Posted February 8, 2017 Author Share Posted February 8, 2017 yes I'm afraid so cruiser it's pointing to that and gee i can't remember if it is airtech either way there is nothing else ive turned all the rocks except that one !thinking it be new but experience has told me in the back of mind just because it be new don't neccessarily mean it can't be faulty ! it may be running but isnt putting enough pressure seems to be the problem I'm going to pull the pump and at same time drop the tank ! both are brand new also the vents on top of tank i special ordered all three maybe sugar in tank I'm guessing a disgruntled brother may also be the problem ! gotta always account for those things too ya know!:( how can i actualy find out if in fact there is sugar in my tank would the signs be gas turned into H20 ? or the fuel in the line gumm up ? gee its a thought ill get back to you tomorrow after ive dropped the tank !! Link to comment Share on other sites More sharing options...
