dante2 Posted February 1, 2017 Posted February 1, 2017 I have the CCV hose off the front of the valve cover all the way to the elbow at the air box. What am I missing and where does it connect? White part inside of yellow box is what I am trying to identify. Thank you for your help.
omega_rugal Posted February 1, 2017 Posted February 1, 2017 that part goes to the air box doesn`t it? i can`t remember, mine fell apart months ago...
ParadiseMJ Posted February 1, 2017 Posted February 1, 2017 It connects to the rear of the air box via a elongated leg u shaped hose. You may find the hose rummaging around in the back room at a NAPA store, if they'll let you. It may be a dealer only option. I found mine the first way, at NAPA. It's too tight of a radius to just use bulk hose.
dante2 Posted February 2, 2017 Author Posted February 2, 2017 I was thinking along those lines but figured I better ask. I will double check and see if the hose is still there just hidden. No not there. Is this what I am looking for?
dante2 Posted February 2, 2017 Author Posted February 2, 2017 Thank you guys. Probably better off replacing both sides at this point. I did notice some loose hoses while I was poking around in there.
