engine temperature light on even though it's not overheating
I'm not a Renix expert, but I think my knowledge still applies.  The switch is located at the back driver side of the cylinder head.  Grounding the wire going to the switch makes the light come on.  Your problem seems to indicate the wire is somehow being grounded.  Did the wire somehow get pinched during the blower fan swap?  Also a quick check to see if the switch just happened to go bad, do a continuity check-- remove the wire lead and check for continuity between the post of the switch and a known ground.  If you have continuity, the switch is "on" all the time and needs replaced.
