stevekop Posted January 1, 2017 Posted January 1, 2017 I have a 1989 Jeep Comanche with a leak in the fuel tank. 1. How do I remove the tank it appears to have a skid plate over it 2. I know that replacement tanks are available, but do they make one out of plastic and should I even consider it. Steve
SBpunk Posted January 2, 2017 Posted January 2, 2017 There is a skid plate with a few bolts on it. Not hard to do. The tank is held on by 3 straps (or 2 depending on the tank size) Need a deep socket or a ratcheting wrench. Drain the tank first with either a manual pump or unhook the feed line out of the tank and drain it that way. Even if it has a little bit of gas its going to be a pain. Unplug the sending unit before dropping it. Once you do that drop the tank just a little and reach up top to unplug the breather tubes. I'd drop the rear driveshaft also but not necessary. I'm short so without the driveshaft I fit pretty easily to keep it balanced while a buddy lowered the jack. Get a new metal tank off Ebay it'll come with the new rings you need. I used vasoline to keep the rubber gasket in place when I put the pump back on. Put the new tank on a bench or back of the truck, put a little bit of gas in it then put everything together. Tip it over to make sure its not leaking before putting it back up in the truck. Good luck
johnj92131 Posted January 2, 2017 Posted January 2, 2017 I have never seen a plastic OEM gas tank for the Comanche. You can find new, steel replacement tanks on Amazon and Ebay for less than $100, depending on size.
DirtyComanche Posted January 2, 2017 Posted January 2, 2017 Unfortunately none of the replacement tanks are plastic. I purchased a Spectra Premium steel replacement tank for my shortbox, and I feel it is of acceptable quality and will probably last quite well. I did go to the effort to paint it for added rust protection though. For a plastic tank guys have been able to use Dakota ones, however the pump and sender are different and it would not be a direct bolt in.
