Fuel sending unit
I dropped the tank on my '89 MJ this morning to swap in a new tank. Found the soldered joints where the lines pass through the plate broken loose.
Knowing the part isn't available, I decided to repair mine. It turned out pretty good. A propane torch, solder, flux, and a couple of stainless steel brushes were all that was needed.
http://m.homedepot.com/p/Oatey-H-20-5-Water-Soluble-Paste-Flux-Kit-with-Safe-Flo-Solder-506912/202515582
Biggest issue is getting it clean. I used a stainless steel wire brush, then heated and applied flux, then wire brush again. I hit it several times. Once I was satisfied with how clean it was, more flux and sweated the solder in.
