Mac8 MJ
Mac8
Started a new project, got a 1990 MJ with the inline 6 and 4x4. I installed a rough country 4.5 inch lift, and 31's. while I was in there I replaced the front brake lines, calipers, and pads. Problem is I'm not able to bleed them or get fluid to the calipers. Thinking I got a master cylinder problem. Any help is much appreciated.
Did you let the master cylinder run dry? You'll need to bleed it first. Also make sure the bleed nipples are pointed up on the callipers. The casting is the same for both sides, only difference is where it's drilled for the nipple.
Is it actually stuck in 4wd, or is the indicator light just on because the vacuum switch is screwed or the CAD won't disengage?
Smoke from the dip stick ain't good.  Make sure it's not overfilled with oil, then compression check and go from there...  The engine is probably less than healthy.
  • 3 weeks later...
Man I wish I understood. The only place that I can fill or even check the fluid level is on the over flow tank. I'm not liking it. Not sure why it's set up this way and not sure that it's factory. I'll try to post a pic tomorrow. Also I'll post a pic of the flatbed I'm going to try and build.
  • 4 weeks later...
  • 1 month later...
That looks bad.  I'd guess there is more to the story though.  I'd suggest doing a leakdown test to confirm that there is definitely dead cylinders.  Or take the head off and just visual things.
If it is dead, find another 4L.  The 87-90 Renix version would be the most direct swap, but you can use a HO from an XJ Cherokee or ZJ Grand up until they stopped building them, but be careful with TJ/WJ engines as the later ones have different mount bosses on the block.  To make the CPS work if you're using a HO engine you have to retain the flywheel or flexplate you have.
  • 4 weeks later...
