Horn not working on my 1988
The first thing to check is whether or not you have power at the horn when the button is pressed. On my '88 Chief, I had power at both horns, but no sound. Removing the horns and cleaning up the ground contacts fixed it.
My horn quite working, this was the only way I could fix it.  There was no continuity to ground from the horn button down through the steering column.  I had to put the jumper ground wire over both of the U-joints, I only picture the lower one for ease of photo.  My best guess is the grease in the u-joints has dried and hardened to the point of being an insulator.  Now that I think about it, I should go buy new u-joints and get those old ones out of there...
