1990 2.5L tps question.
Hello, was just wondering if the 1990 2.5L tps is the same as one from a 4.0L?
Buddy of mine has a 2.5L that is revving up and down at part throttle.
Figuring to see what can be done cheaply - as in if I have any parts that will work for him?
What causes should I look at? 1990 2.5L 5spd (looks to run the Renix system) .... Could a Bad IAC be another possible culprit? O2 sensor?
He's put a new fuel pump in a few months back already.
Sent from my SM-G930W8 using Tapatalk
The 2.5 and 4.0 TPS have different part numbers, so probably not interchangeable. Also the manual and auto tranny models use different TPS's for each.
The 2.5L lists as a Standard Th31... I'm thinking it may mean that it uses an unmodified GM part... Does anyone have the TPS wiring pinout for a 1990 2.5L to confirm?
The 4.0L used a TH32 with a modified pinout specific to Renix. By re arranging the wires I have modified my own 4.0 to use the GM part instead of the AMC variation.
I would like to confirm the 2.5's needs if possible.
