Jaxso32 Posted October 28, 2016 Author Share Posted October 28, 2016 Using a 96 set up with a 318 was actually the original plan for my MJ so I could have obd2 and retain the older style dash and that will be my fall back if I can't figure out a different engine. At the same time it would be nicer to have a newer more efficient engine even if it is more work. I had actually thought about using the vw diesel but it seemed like a lot of work to convert to 4wd Link to comment Share on other sites More sharing options...
G O B Posted October 28, 2016 Share Posted October 28, 2016 At heart I am a MOPAR purist- BUT the old nail head Buick motor found in Land Rovers is 1/2 the external size and weight of a 318. Should end up about the same weight OR LESS than the stock 4.0. Link to comment Share on other sites More sharing options...
Jaxso32 Posted November 8, 2016 Author Share Posted November 8, 2016 The dodge v10 actually isn't that big, I have a bare block at school I can measure it's only about 30" long which is still shorter than the 4.0l I think? Link to comment Share on other sites More sharing options...
gogmorgo Posted November 9, 2016 Share Posted November 9, 2016 It's close. I'd have to remeasure because my memory's fuzzy but I want to say when I did about a month ago it was 32". But the v10 will be wider for more of that length. I can definitely see needing some firewall mods. Link to comment Share on other sites More sharing options...
shelbyluvv Posted November 9, 2016 Share Posted November 9, 2016 A lot of firewall mods. Don't forget there will be a bell housing to clear as well. Basically from the booster to the heater core will need to be cut out. Like I said. I put a 5.2 in my truck and it is stupid tight. Link to comment Share on other sites More sharing options...
Jaxso32 Posted November 9, 2016 Author Share Posted November 9, 2016 no doubt that you will need some modifications, but figured i would give gogmorgo some hope for a v10 comanche Link to comment Share on other sites More sharing options...
