Marine1Texas Posted October 8, 2016 Share Posted October 8, 2016 Well today it was rain pretty good and was in the back 40 in 4wd. None the less when I got back to the house my rear end is making some noise. I put it on the lift and yep noise from rear end, then removed the back cover and yep 3 teeth from ring gear are in the bottom of the dana 44 case. I am running 3.31 in front and back. So I need a new ring and pinon at least. the Dana will go up to 3.73 before I have to change, however the front carrier break is maxxed at 3.55. You think 3.55 all the way around is good enough? or you think I should lay the cost out for the new carrier in the front and go 3.73. the other thing is try to find another dana 44 with 3.31! I removed the ring and put everything back in so that I can still drive it but have to use the front wheel drive till I get ordered the new parts. By the way it is a 87 mj 4.0 with oversized throttle, larger injectors, ax15 with np241 metric ton version. Link to comment Share on other sites More sharing options...
1989 comanche mj Posted October 8, 2016 Share Posted October 8, 2016 I would go with 456 front and rear, or do it cheap with a used 331 gear set. But, something probably happened with the pinion to strip the teeth like that. Link to comment Share on other sites More sharing options...
Marine1Texas Posted October 8, 2016 Author Share Posted October 8, 2016 yea the pinion bearing broke is what happen. I pulled the pinion and seen it was trashed. so I would not leak trany fluid from the transfer case I put a new bearing in on the pinion, and took out the ring gear. I always save my old ones so I have a few in the shop. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 8, 2016 Share Posted October 8, 2016 For the 44 you can use a "thick" R&P gear set, retain your existing carrier, and go to any ratio above the carrier break. I did this when I regeared my D44 from 3.55 to 4.10. Works great. I don't know if they make thick gears for the front D30 though........... Link to comment Share on other sites More sharing options...
Marine1Texas Posted October 8, 2016 Author Share Posted October 8, 2016 I will check for the thick gear for the 30, I am not sure they make them. I know they don't make them for the 35, or the 15. But on my old Humvee with the dana 20 they made the thick ring gear, however it was a 2.73. Thanks for that Hornbrod I forgot all about the thick gears. Link to comment Share on other sites More sharing options...
Marine1Texas Posted October 19, 2016 Author Share Posted October 19, 2016 I am all finished, I got a dana 44 with 4.10 for the front. I also was able to get a new carrier with ring and pinion for the rear dana 44 with 4.11. took all day to do the front swap and the rear carrier install and lining all up. While I was under the truck I replace all the U joints, front back seems like a crap load of them. I also took apart my transfer case and added the novak adapter so I can use the 2wd low so I don't have to have in 4wd low when towing thru fields. I can say it pulls a bit better thru the mud with the lower gears and just happy to have another work truck on the farm working again. Link to comment Share on other sites More sharing options...
Eagle Posted October 19, 2016 Share Posted October 19, 2016 I am all finished, I got a dana 44 with 4.10 for the front. I also was able to get a new carrier with ring and pinion for the rear dana 44 with 4.11. took all day to do the front swap and the rear carrier install and lining all up. While I was under the truck I replace all the U joints, front back seems like a crap load of them. I also took apart my transfer case and added the novak adapter so I can use the 2wd low so I don't have to have in 4wd low when towing thru fields. I can say it pulls a bit better thru the mud with the lower gears and just happy to have another work truck on the farm working again. Nice setup! What did you use for the front Dana 44, an axle out of a Wrangler Rubicon? Link to comment Share on other sites More sharing options...
Marine1Texas Posted October 20, 2016 Author Share Posted October 20, 2016 yeap you know your stuff! so guy on craigslist totaled his Rubicon and was parting out, only had 13k on it! Link to comment Share on other sites More sharing options...
MJ_Milam Posted October 23, 2016 Share Posted October 23, 2016 Correct me if I'm wrong but I believe 3.92 is the carrier change for d44 and d30's Link to comment Share on other sites More sharing options...
Pete M Posted October 25, 2016 Share Posted October 25, 2016 I am all finished, I got a dana 44 with 4.10 for the front. I also was able to get a new carrier with ring and pinion for the rear dana 44 with 4.11. took all day to do the front swap and the rear carrier install and lining all up. While I was under the truck I replace all the U joints, front back seems like a crap load of them. I also took apart my transfer case and added the novak adapter so I can use the 2wd low so I don't have to have in 4wd low when towing thru fields. I can say it pulls a bit better thru the mud with the lower gears and just happy to have another work truck on the farm working again. imo lower gears have the best kick-in-the-pants-per-dollar-spent ratio :D Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 25, 2016 Share Posted October 25, 2016 Correct me if I'm wrong but I believe 3.92 is the carrier change for d44 and d30's D44 carrier break = 3.73 & down / 3.92 & up Link to comment Share on other sites More sharing options...
