Question about transmissions
The AX-5 will for sure (it's the most common 5speed found behind 2.5 and 2.8L engines), but the AX-15 (and Peugeot) found behind the 4.0Ls won't bolt up. Although the AX-15 is technically possible with either the aftermarket adapter or some creativity with a certain Dakota bellhousing.
The AX-4 and AX-5 are the same transmission. The AX-4 just has a bunch of empty space where the 5th gear parts go in the AX-5.
Does that mean I could buy the AX-5 gear set, and put it into the tranny I have?
