xjustinx Posted September 9, 2016 Share Posted September 9, 2016 I need to split my transfer case to reseal it, is there any harm spraying the guts with brake cleaner or something similar? Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted September 9, 2016 Share Posted September 9, 2016 I'm about to do this, I'm interested as well Link to comment Share on other sites More sharing options...
yxmj Posted September 9, 2016 Share Posted September 9, 2016 As long as it is allowed to dry what could it harm?? Is the tcase out ? If so be sure by sacrificing a quart or 2 of atf...put it back together temporarily ....without sealing it....add some atf and turn it over by the front output while it is engaged (run it through the gears if you are inclined) then drain that fluid...split it ...lay it open side down for a bit....then wipe it down and re-assemble it....just think of it as doing the dishes... Link to comment Share on other sites More sharing options...
xjustinx Posted September 9, 2016 Author Share Posted September 9, 2016 It will still be in the truck. I'm just taking the cover off. Link to comment Share on other sites More sharing options...
zomeizter Posted September 10, 2016 Share Posted September 10, 2016 spray cleaner, let completely dry, put together, refill with adequate lube, drink beer and enjoy a job well done! Link to comment Share on other sites More sharing options...
