Handy little tool
kroyusa
Had this in the garage from my days as a tech. Used it last week to solder wires together under my buddy's F150 and it worked great. The soldering tip put enough heat on the wires to suck in the solder. There's a tip in the kit that puts out heat without flame and that worked great on the heat shrink.
I've also been using the torch tip to heat stuff as I disassemble my Comanche. Helped me get the brake lines out of the distribution block, front bumper bolts and steering box bolts so far.
