1989 comanche mj Posted August 15, 2016 Posted August 15, 2016 I have the steering linkages from a 94 zj v8 4x4. Will it directly bolt on to my 92 MJ- tie rod and pitman arm ends the same hole diameter and taper? I have been reading, and it goes back and forth about using just parts not the whole setup.
dragordie Posted August 15, 2016 Posted August 15, 2016 Everything on my MJ was donated by my 96 ZJ Truggy. All the steering components where from a 98 V8 ZJ Plus I plan on doing a hydro assit with the gear box
DirtyComanche Posted August 15, 2016 Posted August 15, 2016 I haven't done it, but apparently you can run into issues if you don't have much/any lift as the drag link is a little longer, but it's can be fixed by grinding a a bit off the threaded end of the drag link.
Knucklehead97 Posted August 16, 2016 Posted August 16, 2016 I haven't done it, but apparently you can run into issues if you don't have much/any lift as the drag link is a little longer, but it's can be fixed by grinding a a bit off the threaded end of the drag link. or just use the MJ drag link as they are the same in strength from what I've heard. I just ordered all new steering parts and I went with a ZJ tierod set up with MJ drag link.
