ComancheLover90 Posted August 14, 2016 Share Posted August 14, 2016 so i broke the hazard button off when i was doing something with the ignition switch and cannot find another replacement hazard button, i've looked and am not able to screw anything in and was wondering if anyone knew where to get one, that would be very helpful! Link to comment Share on other sites More sharing options...
schardein Posted August 15, 2016 Share Posted August 15, 2016 If you just need a replacement button, I'd look for one at a junk yard. They are the same as XJs so finding one shouldn't be to difficult. One the other hand, if the piece inside the column, that you screw the button into, is the problem, then you need a new turn signal switch. The hazard/4 way flasher is a part of it. Link to comment Share on other sites More sharing options...
Minuit Posted August 15, 2016 Share Posted August 15, 2016 If you can't find one from a Jeep I'm 98% sure that one from a GM vehicle with the same column will work. Our trucks use GM steering columns after all and most parts will interchange. Link to comment Share on other sites More sharing options...
sinkrun Posted August 15, 2016 Share Posted August 15, 2016 I think this is it? http://www.ebay.com/itm/Complete-Hazard-Button-OE-Chevrolet-GMC-Buick-Oldsmobile-Pontiac-Cadillac-Jeep-/262080301441?hash=item3d05340981:m:maO1X5RXf8vKWtQVBZjWEIA&vxp=mtr Link to comment Share on other sites More sharing options...
