Jortega3333 Posted August 2, 2016 Share Posted August 2, 2016 So I have read a lot about the blower motor issue and resistor issue but my symptoms are a little different in that my heater and AC work fine and the blower works in all fan speeds, but will eventually slow down in the volume of air it puts out. Is this still the same issue with the resistor and or blower replacement? Any ideas and help is appreciated. Thank you Link to comment Share on other sites More sharing options...
Eagle Posted August 2, 2016 Share Posted August 2, 2016 Does the blower really slow down, or does the air start coming out of the defrost outlets on top of the dashboard when you're going uphill? Link to comment Share on other sites More sharing options...
Jortega3333 Posted August 2, 2016 Author Share Posted August 2, 2016 Only tried with AC and it always comes out the front vents just a lower volume, but sounds like the fan is still operating at same speed. Seems like it is after the fan has been running for about 15-20 minutes. Link to comment Share on other sites More sharing options...
Eagle Posted August 2, 2016 Share Posted August 2, 2016 Have you checked to see if air comes out of the top of the dash when the front vents seem to slow down? Does it happen mostly when going uphill or under load? The ventilation system is controlled by vacuum. The system is set up such that when vacuum is lost, the flapper doors default to sending air to the defrost outlets on the top of the dashboard. Loss of vacuum is usually caused by deterioration of the hoses to the vacuum reservoir behind the front bumper on the passenger side, or by damage to the reservoir itself. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 2, 2016 Share Posted August 2, 2016 Try what Eagle suggests first. If that's all working well, do this: http://cruiser54.com/?p=211 Link to comment Share on other sites More sharing options...
SVPete Posted August 2, 2016 Share Posted August 2, 2016 What Cruiser said ^^^^^ Experienced your issue also. In the process of cleaning ground connections, it went away. The ground terminal for my heater was also installed upside down (from the factory), which means it was barely making contact with the body. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 2, 2016 Share Posted August 2, 2016 What Cruiser said ^^^^^ Experienced your issue also. In the process of cleaning ground connections, it went away. The ground terminal for my heater was also installed upside down (from the factory), which means it was barely making contact with the body. Yup. And if there's a bad ground, the brown wire on the ignition switch, along with the switch itself, tends to fry. Link to comment Share on other sites More sharing options...
Jortega3333 Posted August 3, 2016 Author Share Posted August 3, 2016 Thanks for the info guys, sounds like a couple good ideas to try. I will let you all know how it goes. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 4, 2016 Share Posted August 4, 2016 Thanks for the info guys, sounds like a couple good ideas to try. I will let you all know how it goes. Do these and see what happens: http://cruiser54.com/?p=19 http://cruiser54.com/?p=35 http://cruiser54.com/?p=211 Link to comment Share on other sites More sharing options...
