Renix Starter Relay Question
What does the double green ring terminal wire go to and/or control?
I've been having a huge parasitic draw and finally tracked it down to that wire. I removed it from the relay and it magically fixed a couple issues I've been having. Mainly no more draw and the motor shuts off instantly with the key instead of running for a couple seconds.
Thanks for the replies. Parking lamps would make sense, they blow the fuse after being on for around 15 mins. I never really drive it at night so it's been low on my list.
The weird thing is everything seems to work, including parking lamps, when the double green wire is removed. The lights did look a bit dim though. I'll have to do some more testing.
