4 - speed manual trans fill plug location ?
 The service manual says it's on drivers side. the only thing I found on drivers side says  don't remove on it. it has a torx fitting, some big one.
 it :hmm:  is a seamless tranny I don't know what kind. except it's a 4-speed. 86 Comanche 150 ci. Thanks for your help . I drained tranny now can't locate the right fill plug.
AX4 fill location is passenger side of the trans picture below
alternatively there is a torx plug on the driver side of the trans, about half way up the side that can be used to fill as well.
Also you can fill from the shifter hole
Image Not Found
I found it,thanks for the pic. I got it out with a pair of vise- grips and filled her  back up with fresh 75- 90 w  synthetic blend,just made a test drive and it shifts ever so smooth.thanks again man .I have gotten so much good knowledge from this site,it's great !!! :thumbsup:
