what size is the nut on the pitman arm?  and do you have to drop sway bar to pull it off, and do you have to pull skid plate off.  thanks!!!
I just removed it 2 weeks ago, and had to buy a socket.... I "Think" it was 18mm... I'll go check my tools in a bit and post again the size I got
the biggest i had was a 1 3/16 and it was too small .I had a 36mm and it was too big. just thought some one might know off hand.
33mm / 1-5/16" wrench will work. I don't have either so I used a BF pipe wrench - worked fine.
Ditto.
thanks, hornbrod :thumbsup:
