1J7FT26E0KL422185
cyclopsic
1990 Ford 302
-Stage 1 Trick flow Roller cam
-Factory internals
-Hastings file fit racing pistons rings
-block professionally honed and measured
-no machining was required
-factory fuel injection heads
-stage one professional products split runner intake
-Holley 500 CFM carburetor
-Trick Flow double spring valve springs
-March performance serpentine with underdrive pulleys
-Shorty headers
-high volume melling oil pump
-Ford racing cobra flywheel
-Ford racing clutch
-ARP hardware
-Clevite bearings
-Fel-pro gaskets
1991 Borg/Warner World Class t-5
-Factory Mustang transmission
-White Lighting Hurst short shifter
-Ram racing hydraulic throw-out bearing
-Wilwood master cylinder with stainless lines
Front axle
-Dana 30 non-drive beam axle
-1998 Jeep Grand Cherokee was the donor
-Knuckles are from a 99 Cherokee
-new ball joints and brakes
-new upper control arm bushings
-Rusty’s 3” lift springs with two ¾” spacers to adjust the stance
-Pro-comp Shocks
Rear Axle
-unsure of the year, Chrysler 8.25
-differential housing welded to the tubes
-homemade skid under the differential
-Chrysler factory posi unit (NEW)
- 4:11 to 1 richmond sportsman gears
-new bearings and complete rebuild
-TNT customs u bolt eliminators, and spring over conversion
-Pro Comp shocks
-Disc brakes from 98 Grand Cherokee
-professionally cut and balanced rear driveshaft
Body
-Hanneman’s Fiberglass bedsides and front fenders
-1968 Mustang front scoop
-97+ front header panel conversion
-97+ rear taillights
-factory Chrysler roll bar in bed
-22 gal fuel cell in bed
-Flat tan paint
-new floor pans
-new rocker panels
-NO RUST
-97+ doors
Interior
-Custom reupholstered factory seats (headrest deleted)
-sliding rear window
-brand new front window
-manual windows and locks
-Omega custom gauges
-complete rewire with new wiring harness
-new carpet
-new pedals
-Weather tech window vents
-factory rear tint, the glass in the doors will be tinted shortly
-factory AM/FM radio
-pioneer door speakers
  • 3 years later...
*X2 TRIM STYLE X2 - VINYL BENCH
-YY
151 Zone 51-Chicago
1AA U.S. Dealer Retail
5AL Low Series Tracking
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DCK 4SPD MANUAL TRANS - AISIN SEIKI
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
EPD ENGINE - 2.5L I4 TBI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JKB MOPAR Hood Lock
K3Z STRIPE/BADGE/MOLDING/COLOR
KDC
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PY7 SAND PRIMARY PAINT - HY7
QY7 SAND SECONDARY PAINT - HY7
RAA All Radio Equipped Vehicles
RAC AM MTR Radio
RCA 19 SPKRS SRT High Perf Audio
SAA Manual Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YEA No Optional Sales Codes
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
Z75 Right Front Spring Group V
Body Model TL61
Build Date 9/8/88
  • 1 year later...
