cyclopsic
cyclopsic's Achievements
  1. 1990 Ford 302 -Stage 1 Trick flow Roller cam -Factory internals -Hastings file fit racing pistons rings -block professionally honed and measured -no machining was required -factory fuel injection heads -stage one professional products split runner intake -Holley 500 CFM carburetor -Trick Flow double spring valve springs -March performance serpentine with underdrive pulleys -Shorty headers -high volume melling oil pump -Ford racing cobra flywheel -Ford racing clutch -ARP hardware -Clevite bearings -Fel-pro gaskets 1991 Borg/Warner World Class t-5 -Factory Mustang transmission -White Lighting Hurst short shifter -Ram racing hydraulic throw-out bearing -Wilwood master cylinder with stainless lines Front axle -Dana 30 non-drive beam axle -1998 Jeep Grand Cherokee was the donor -Knuckles are from a 99 Cherokee -new ball joints and brakes -new upper control arm bushings -Rusty’s 3” lift springs with two ¾” spacers to adjust the stance -Pro-comp Shocks Rear Axle -unsure of the year, Chrysler 8.25 -differential housing welded to the tubes -homemade skid under the differential -Chrysler factory posi unit (NEW) - 4:11 to 1 richmond sportsman gears -new bearings and complete rebuild -TNT customs u bolt eliminators, and spring over conversion -Pro Comp shocks -Disc brakes from 98 Grand Cherokee -professionally cut and balanced rear driveshaft Body -Hanneman’s Fiberglass bedsides and front fenders -1968 Mustang front scoop -97+ front header panel conversion -97+ rear taillights -factory Chrysler roll bar in bed -22 gal fuel cell in bed -Flat tan paint -new floor pans -new rocker panels -NO RUST -97+ doors Interior -Custom reupholstered factory seats (headrest deleted) -sliding rear window -brand new front window -manual windows and locks -Omega custom gauges -complete rewire with new wiring harness -new carpet -new pedals -Weather tech window vents -factory rear tint, the glass in the doors will be tinted shortly -factory AM/FM radio -pioneer door speakers
