A long time ago somebody sent me a link for the metric fittings to use on an AW4 to delete the quick disconnects.  They were a metric to AN fitting.
That was a laptop or two back in time, so I've lost the link.  I think Summit or Jegs sold them.
Anyone have any ideas?  I hate the quick disconnects with a passion.
Don, any idea if you're supposed to use O-rings or crush seals on those fittings?  I'm guessing O-rings, but have never taken the fittings out of an AW4 before.
I finally found a source for the quick disconnect to AN fittings for the radiator side. Upper firing can be swapped with a 3/8" male inverted flare fitting, but the lowers on most rads are soldered to the cooler. The fitting mate to that tube and allow a -6AN fitting to be attached. They are a 3/8" GM fuel/oil/trans fitting when searching. Found mine on eBay, as usual these days. So now I finally have all the fittings needed to re-plumb the XJ's AW4 ... And a complete solenoid kit as well.
Sent from my SGH-I337M using Tapatalk
