Jeepmmmj Posted April 30, 2016 Share Posted April 30, 2016 Has anyone ever taken a headliner board from an xj and cut it to,fit into their mj? Would this even be possible? It seems like a good idea to me but I figured I would ask first.. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 30, 2016 Share Posted April 30, 2016 Some guys here have done it, but it isn't a straight-forward process. I believe that is due to the different roof angle between the MJ and XJ. Link to comment Share on other sites More sharing options...
Nofeartoys Posted May 1, 2016 Share Posted May 1, 2016 I posted in DIY section on this site with my headliner design. Using a piece of plywood. It came out pretty good. Material can be purchased on eBay in various colors. I choose dark grey Link to comment Share on other sites More sharing options...
Jeepmmmj Posted May 4, 2016 Author Share Posted May 4, 2016 Thanks you guys! Link to comment Share on other sites More sharing options...
75sv1 Posted May 4, 2016 Share Posted May 4, 2016 I am in the process or at least tried this. I cut the front and then the rear to match. I plan to take some of the center section to glue on the back as a reinforcement. I am going to try and put in the 98-up sound bar. Yeah the speaker will be right at my ear. I also plan to put in the navigation over head. I'll have to cut it a bit and put in the reinforcing plate or whatever you want to call it. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 4, 2016 Share Posted May 4, 2016 I am in the process or at least tried this. I cut the front and then the rear to match. I plan to take some of the center section to glue on the back as a reinforcement. I am going to try and put in the 98-up sound bar. Yeah the speaker will be right at my ear. I also plan to put in the navigation over head. I'll have to cut it a bit and put in the reinforcing plate or whatever you want to call it. :popcorn: Link to comment Share on other sites More sharing options...
75sv1 Posted May 4, 2016 Share Posted May 4, 2016 I am in the process or at least tried this. I cut the front and then the rear to match. I plan to take some of the center section to glue on the back as a reinforcement. I am going to try and put in the 98-up sound bar. Yeah the speaker will be right at my ear. I also plan to put in the navigation over head. I'll have to cut it a bit and put in the reinforcing plate or whatever you want to call it. :popcorn: I think you'll get fat on pop corn. I've been working on this for quite some time. But keep the Indiana economy going. I have been doing a few things on it. Need to get the WJ 4.0L figured out, then axels. Then electronics or interior. Lots to do. If other vehicles behave. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 4, 2016 Share Posted May 4, 2016 You might actually be better off finding a headliner board out of a similar pickup size/design of another brand. Like an S-10 single cab or a Ranger single cab. Haven't researched it, but seems like it'd be a better starting point than cutting up an XJ headliner and trying to glue it back together. The curve of the back of the MJ cab is nothing at all like the back of an XJ. Just throwing that out there. Link to comment Share on other sites More sharing options...
