jimoshel Posted April 30, 2016 Posted April 30, 2016 When you,re using a tow dolly to move another vehicle, should the front wheels be fastened on the vehicle being towed? Or let them move freely?
mikekaz1 Posted April 30, 2016 Posted April 30, 2016 Uh... you should probably strap down the vehicle to the dolly
gogmorgo Posted April 30, 2016 Posted April 30, 2016 Depends on the dolly. Some are articulated, so the bit the wheels sit on pivots. If you have one that doesn't pivot, I imagine going around corners would put a lot of stress on the steering wheel lock pin if you leave the steering locked.
jimoshel Posted April 30, 2016 Author Posted April 30, 2016 I have two dollies. The one where thewheel mounts turn with the load. and the other one. I don't use it at all.
Eagle Posted April 30, 2016 Posted April 30, 2016 The only dollies I've ever seen have the front wheels of the towed vehicle strapped tightly to the dolly. There is no strain on the steering mechanism at all, because the front wheels of the towed vehicle don't (can't) turn.
mikekaz1 Posted April 30, 2016 Posted April 30, 2016 The only dollies I've ever seen have the front wheels of the towed vehicle strapped tightly to the dolly. There is no strain on the steering mechanism at all, because the front wheels of the towed vehicle don't (can't) turn. I agree.
gogmorgo Posted April 30, 2016 Posted April 30, 2016 The wheels can't turn relative to the dolly, but that doesn't mean they won't turn relative to the rest if the towed vehicle. It's not like the rear wheels and dolly wheels are moving through the same radius when you're going around corners.
