magealexstra Posted April 22, 2016 Share Posted April 22, 2016 Hello, Well I started this thread in the pub under my intro. Though I thought it best to move in here. Here's a pic of the truck. Still needs some work and seeing as I had another question I'm going to just start fresh. Anyway my question is, after I rebuild the steering box. How do I align it for reinstall. By that I mean, adjust the shaft so my steering is aligned. the walk through that I'm following doesn't cover this and I couldn't find anything under steering box install on here. Anyway thanks in advance. :) Link to comment Share on other sites More sharing options...
13 Legion Posted April 22, 2016 Share Posted April 22, 2016 Welcome first off! Nice looking truck. My advice is to buy yourself a Haynes Repair Manual for the Jeep Cherokee 1984-2001. This single manual covers the Cherokee, Wagoneer as well as Comanche. Readily available at your local parts store. Chapter 10 covers suspension and steering. Not sure if you have power or manual steering. I replaced manual gearbox and it was pretty straightforward in the Haynes book. Why are you choosing rebuilding original unit over replacing? Just asking unless you know exactly what the culprit is. Some one else will chime in if its a power unit to help you out. Again good looking truck! Link to comment Share on other sites More sharing options...
magealexstra Posted April 22, 2016 Author Share Posted April 22, 2016 Thanks, I picked up the haynes manual for a song online. Most of the information seems to be general automotive maintenance. I'll look again to see if there's an explanation to my question. The truck has power steering. It's got a leak in the front and bottom seal but overall seems to be good. Plus I like the challenge of rebuilding. I'll post some more pics as I move through the rebuild. Thanks again :) Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
magealexstra Posted April 22, 2016 Author Share Posted April 22, 2016 Ok so I looked it up. It says to mark it's position. So I guess I'll just have to keep up with the markings as I go about cleaning. Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
magealexstra Posted April 23, 2016 Author Share Posted April 23, 2016 So here's the steering box ripped apart. I already put it back together and reinstalled it but I'm out of power steering fluid. So I'll let you know how it went tomorrow. Link to comment Share on other sites More sharing options...
magealexstra Posted April 24, 2016 Author Share Posted April 24, 2016 So I'm flushing radiator. because, so far everything the PO told me he did doesn't seem to have been done... ever. After emptying the system I think, let's go ahead and flush it. So I start taking off the air box so I can get to the bolts to pull the thermostat. Finding yet another present... Now I know what your thinking. Oh this guy left the bolt off but you'd be wrong. He broke the bolt off in the block. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 25, 2016 Share Posted April 25, 2016 Link to comment Share on other sites More sharing options...
13 Legion Posted April 25, 2016 Share Posted April 25, 2016 This happens. See if there's enough of bolt left sticking out to heat. Than grab a pair of vise grips. Broke 3 bolts recently between changing gearbox and water pump. If not you will have to drill out. Was the thermostat housing leaking prior to noticing this? Link to comment Share on other sites More sharing options...
magealexstra Posted April 25, 2016 Author Share Posted April 25, 2016 Not that I was aware of but it would account for the general wetness in the engine bay. I already bought the valve cover gaskets. So that's happening. :) whenever i get in there to do that ill clean everything off, repaint, drill it out and re-tap the hole. Also I have a question regarding the carburetor. Inside of it there seems to be window screen stuffed in the right side. And, in what i belive to be the carb vent there is some kind of paper. What would this be for? While removing the charcoal canister and most of the emissions items i.e. erg. I found similar forms of blockage. Between the main vacuum line and the erg, let's call it an actuator, there was a black silicone of some kind. Could have been rtv but I'm not sure. Link to comment Share on other sites More sharing options...
magealexstra Posted April 26, 2016 Author Share Posted April 26, 2016 Would these replace what I have on my jeep? It's an 86 xls Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 26, 2016 Share Posted April 26, 2016 Unless you want the rear 4" higher than it is now, no. I won't recommend cRusty's parts to anyone either. Look up Hell Creek and give Tom a call. He is a member here and will treat you right. He has stock rear packs, metric ton, or 3"-4.5" packs. Link to comment Share on other sites More sharing options...
outlaw star Posted April 26, 2016 Share Posted April 26, 2016 Would these replace what I have on my jeep? It's an 86 xls We put those on a friends MJ. They aren't stiff but gave it more of a 6" lift instead of 4". We put XJ shackles on to lower it a bit to around 5". Link to comment Share on other sites More sharing options...
magealexstra Posted April 26, 2016 Author Share Posted April 26, 2016 Unless you want the rear 4" higher than it is now, no. I won't recommend cRusty's parts to anyone either. Look up Hell Creek and give Tom a call. He is a member here and will treat you right. He has stock rear packs, metric ton, or 3"-4.5" packs.I'm guessing it's hell Creek suspension? I just want to return it to stock for now. later on I plan to put in a rough country lift. I'll take a picture of my rear end in a bit so you can see my problem. Link to comment Share on other sites More sharing options...
Megadan Posted April 26, 2016 Share Posted April 26, 2016 General Springs stock replacements. It's what I have under my truck for 2 years now and they sit exactly at stock ride height measures now that they have settled some. Link to comment Share on other sites More sharing options...
magealexstra Posted April 26, 2016 Author Share Posted April 26, 2016 General Springs stock replacements. It's what I have under my truck for 2 years now and they sit exactly at stock ride height measures now that they have settled some.Did you go with the 1280 lb or the 1700 lb? Link to comment Share on other sites More sharing options...
magealexstra Posted April 26, 2016 Author Share Posted April 26, 2016 Don't mind the siding. I have her parked in a weird spot so I could lift the front up. Is this some kind of helper spring? It's only on one side. Link to comment Share on other sites More sharing options...
Megadan Posted April 26, 2016 Share Posted April 26, 2016 Yea, that's a helper spring. Should be 1 per side. I'd remove it and call it a day. Those leaves look like they have flattened a little, but still have some life left in them. If you do want to replace them with new ones, I went with the 1280, which are factory replacement. the 1700lb springs are Metric Ton replacements. They also have another spring option with a military wrap on the front eye that is designed to give 1 1/2" lift over stock springs (new or factory ride height). A bit more expensive. http://www.generalspringkc.com/product_p/gsc-571.htm Link to comment Share on other sites More sharing options...
magealexstra Posted April 26, 2016 Author Share Posted April 26, 2016 The springs I have now seem to give a lot more than I would expect. However, I don't really have experience with this trucks ride characteristics. I'd be happy not having to replace them. If I could get away with cleaning them up and painting that would be awesome. Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
Megadan Posted April 26, 2016 Share Posted April 26, 2016 They do give a lot, even my factory replacement springs will give a lot even with my just climbing in the bed. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 27, 2016 Share Posted April 27, 2016 Pull it and see if it squats on that side. If not call it good and spend the money on something else. Good looking truck. I like the 86 MJ, but I'm biased. Link to comment Share on other sites More sharing options...
magealexstra Posted April 27, 2016 Author Share Posted April 27, 2016 Will do. I still have the front end lifted so it'll be a while before I get back there. I'll post a few pictures in a minute of the work I've done so far. Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
magealexstra Posted April 27, 2016 Author Share Posted April 27, 2016 So here's a side by side of the engine bay so far And where she stands now. Still have more to do In the bay, I have: Removed the ac compressor and lines Removed the charcoal box to make room for a second battery. Removed all unnecessary vacuum cans and hoses. Replaced and rewired the alternator, battery pos and neg lines Painted the bay, radiator, behind front grill, brake booster, master cylinder, and a couple of odds and ends. Link to comment Share on other sites More sharing options...
magealexstra Posted April 27, 2016 Author Share Posted April 27, 2016 I don't have a complete picture of the front end before I started. but, here it is in pieces. And as she sits now... I have: Rebuilt the steering box Replaced the center link Replaced the bushing on the sway bar Swapped the front differential fluid Removed the vacuum from the cad and built in an always locked system did a redneck front alignment until I can do it properly Cleaned what I could and greased all joints Link to comment Share on other sites More sharing options...
magealexstra Posted April 27, 2016 Author Share Posted April 27, 2016 Also I replaced the headlights. Link to comment Share on other sites More sharing options...
magealexstra Posted April 27, 2016 Author Share Posted April 27, 2016 Does anyone know what oil pan gasket goes on my truck? It has 14 bolts and lifts in the front and back. I've looked everywhere but can only find 16 bolt and 12 bolt gaskets. A link to one would be greatly appreciated. TIA! :) Sent from my SM-N915V using Tapatalk Link to comment Share on other sites More sharing options...
