What exactly are you looking at? Every MJ will have the cable from the gas pedal to the throttle body. Automatics will have another for the throttle valve, they'll run from the throttle body down to the driver's side of the trans. Cruise control equipped models will also have one running from the throttle body to the cruise unit on the front passenger inner fender.
No. The Renix XJs and MJs have the throttle cable running to a bellcrank mounted on the driver's side frame stub ear. From the bellcrank, IIRC, there's a rigid rod that extends up to actuate the throttle body butterfly.
You misunderstand the sentence. It wasn't the clearest, but I was just identifying what the three cables were for, which was how the question was worded. But good to know. :thumbsup:
