comanche idleing weird
So I have an 88 comanche 4.0 5 speed with 137k. At idle it doesn't stay consistent. It will idle ok then drop off like it's gonna stall then jumps back up high for a little then drops back down to normal idle. It has new vacuum lines, plugs & wires, cap & rotor. Checked the fuel pressure and seems normal. Have any of you guys experenced the same issue and if so what was the cause and cure?
MJanky it doesn't seem to be.
Bignuke and kudo I'll have to check them not sure if they are tight
Cruiser54 bi**hin info man thanks for the site!
Go with the Tips and ignore any other suggestions at this point.
