sinkrun Posted April 6, 2016 Posted April 6, 2016 Can not find a clear answer on how to remove the shafts from the rear d44 in a 89 Comanche so I can have the bearings and seals replaced. Local shop said if I get them out 20.00 a side to remove replace with new if I buy the parts.
Rockfrog Posted April 6, 2016 Posted April 6, 2016 The axle retainers bolt onto the backing plates, undo those and pull the shaft free. Bearings and seals are retained on the axle shaft by a retainer sleeve that needs to be cut off.
sinkrun Posted April 6, 2016 Author Posted April 6, 2016 Wow thats easy no need to get into the diff cover thanks for the info.
sinkrun Posted April 19, 2016 Author Posted April 19, 2016 Just now working on this got the retainer bolts out shaft will not come out any suggestions?
sinkrun Posted April 19, 2016 Author Posted April 19, 2016 Tried slide hammer still nothing. This is a trac loc does this make any difference? Hate to pull the cover if not needed.
ComancheKid45 Posted April 19, 2016 Posted April 19, 2016 Probably just stuck. If all 4 bolts are out of the retainer, try the slide hammer again :thumbsup:
sinkrun Posted April 19, 2016 Author Posted April 19, 2016 Got it you do have to beat the crap out of it, 3 pound hammer beating on the slide hammer did it took good 10mins.
sinkrun Posted April 19, 2016 Author Posted April 19, 2016 Any advice on reinstalling the shaft? I had a local driveshaft shop rebuild it so that parts done.
