1J7FT26L2LL169922
timhump63
1J7FT26L2LL169922
1990 JEEP
1st Position - COUNTRY
1 US
2nd Position - MANUFACTURER
J Jeep U.S.A.
3rd Position - TYPE
7 Truck
4th Position - GVWR
F 4001 - 5000 GVW
5th Position - LINE
T Cherokee or Comanche - 2WD (4WD now)
6th Position - SERIES
2 Base
7th Position - BODY
6 Truck
8th Position - ENGINE TYPE
L 4.0 Litre, I-6
9th Position - CHECK DIGIT
10th Position - MODEL YEAR
L 1990
11th Position - ASSEMBLY PLANT
L Toledo #1
12th thru 17th Position - SEQUENCE
A sequential number assigned by the
manufacturer.
  • 2 months later...
  • 2 years later...
*E1 Cloth Bench Seat
-SA Charcoal
144 Zone 44-Syracuse
1AA U.S. Dealer Retail
4SP Supplemental NY Consumer Protection
5KK First American Title Insurance CO.
ALA SE Decor Group
ALK Italia Package
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Body Model TL62
Build Date  11/1/89
  • 1 year later...
