fire797 Posted April 6, 2016 Share Posted April 6, 2016 I have a 89 MJ. I am a journeymen electrician. I have a good working knowledge of electrical system. I have downloaded the wiring diagram from the link I got on this website. It is for a 1988 MJ. It shows the radio being powered by the ETR fuse (constant 12v) and the wire label is red/tan. My fuse block has a label of ANT were the ETR fuse should be. The wire I have in the harness to the radio (constant 12v) is just red and it goes back to the dome light fuse. So is my harness for a 1989 MJ or has it been replaced with a different year and what year do you think it is????????? Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 6, 2016 Share Posted April 6, 2016 88 and 89 have some major wiring differences. If you want I can look at my 89 FSM to tell you if that matches it, but I'm thinking it does. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 6, 2016 Share Posted April 6, 2016 Not only 88 and 89, but they all have differences in wiring, especially wire color. Suggest you invest in a factory electrical manual specific to your vehicle. It'll pay for itself many times over down the road. Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 7, 2016 Share Posted April 7, 2016 I know on my 91, the dome fuse and the radio fuse are inline with each other and functions swap back and fourth between these two. What's your issue? Link to comment Share on other sites More sharing options...
91Pioneer Posted April 7, 2016 Share Posted April 7, 2016 http://www.revbase.com/BBBMotor/Wd Link to comment Share on other sites More sharing options...
fire797 Posted April 8, 2016 Author Share Posted April 8, 2016 Thank you 91pioneer. great link!!!! problem solved. I cleaned the fuse block and replaced all the fuses and the radio works..... Link to comment Share on other sites More sharing options...
