Iowamike Posted March 30, 2016 Share Posted March 30, 2016 Trying to get floor pans on the cheap. The salvage yard guy in town is a friend an doesnt charge me much. But he only has cherokees in the yard. I could only find a good pan in a 96 he had will it work, an can the carpet be swaped seemed in decent shape. Maybe if i cut the carpet where the cab ends on the truck? Link to comment Share on other sites More sharing options...
Megadan Posted March 30, 2016 Share Posted March 30, 2016 As far as I know the footwell area of the floors is the same, but the midde to back area is a little different. Most XJ made floor pan replacements require a little tweaking to work on an MJ.As for the carpet, maybe, but I have a feeling behind the seats may require a little finesse but I bet it could be made to work. Link to comment Share on other sites More sharing options...
Iowamike Posted March 30, 2016 Author Share Posted March 30, 2016 Thanks, no more flinstone truck. Link to comment Share on other sites More sharing options...
FrankTheDog Posted March 30, 2016 Share Posted March 30, 2016 The 95-01 carpets will have a hump molded in where the front of the seat bracket mounts to. That may prove awkward. 84-94 won't have that. Link to comment Share on other sites More sharing options...
Eagle Posted March 30, 2016 Share Posted March 30, 2016 A friend cut the driver's floor out of the wreck of an '89 XJ I had here and used it to repair his '87 MJ. IIRC he had to fab a copy of the raised rib in the MJ because his was so far gone -- and the XJs don't have that piece. Link to comment Share on other sites More sharing options...
mikekaz1 Posted March 31, 2016 Share Posted March 31, 2016 Fwiw when I replaced the floor. My internal frame support was pretty well gone. So it ends just in front of the seat bracket. I was originally debating just welding in a 1/8 strip in place of it. But I never replaced it. I also haven't seen any I'll effects from not having it (XJs never had it). Link to comment Share on other sites More sharing options...
sbczr2 Posted March 31, 2016 Share Posted March 31, 2016 I have found that it will work but like the other said it does require so help Link to comment Share on other sites More sharing options...
