Iowamike
Everything posted by Iowamike
  1. Oil pans off and the lower half of the seals out. Is there any way to get the top half out with out removing the cam? Various youtube vids show people just tapping it out with a punch. Is there a specific direction i need to tap from and is there a better tool for the job?
  2. Ill get every part you mentioned tonight all ready did the master cylender going to need the braded line as well
  3. It was the master cylender that was empty I spoke incorectly.
  4. Yep its the slave cylender. Guess i'll do the plate when I'm in there, how weak is the ba 10/5. Is it even worth the repair?
  5. So i guess its break fluid because its empty, but the breaks work the clutch don't. I am new to manuals, first one.
  6. So i finally fixed my death wobble. Took the 4.0 manche 5 speed 88 out for a cruze with the old lady. Got about 30 min out and the clutch goes to the floor. I get out to see about a pint or less of hydraulic fluid under her. I know little of trans so any advice would help looks like the leak was at the bell house an engine but havent got a better look yet.
  7. I belive the axle house said dana 313b inside, any one know why theres two extra bolt holes under the diff cover.
  8. I goter done. they still didnt fit perfectly flush like the old one on the exterior of the shafts, i had to r3use the old c clips the new where to fat.
  9. Thanks they where to big the first time they where not c clips. The second time
  10. I can't seem to get a u joint to fit my mj its an 88 4.0 4wd 5 speed. Is it a normal size u joint? autozone has given me two duds so far. A customer behind me, said they can be hard to find one to fit. Never had this problem with my other dana 30s did find two extra bolt hols under my diff cover that had no hole in the cover for them. But I'm pretty sure its stock axle.
  11. I put the missing bulb socket in. It was for the battery light. I guess that was it because they now work not as bright as i thought 3 new bulbs would be but plenty enuff light an the dimer works.
  12. I think th3 temp works never seen it on I'm gona toss the temp sensor for a new one pretty soon.
  13. Just the night lights to see the gauges with out flicken a lighter. flashers an high beam lights work and temp oil an all the warning lights.
  14. I found a missing bulb socket in the cluster could that be it?
  15. Went to the junk yard an all i cqn find is the clusters with the electric hook ups no actual speedo cabled ones.
  16. Yes i triedmthendimmer in all directions and remdid the ground as well maybe its the cluster its self?
  17. Ok so i put new bulbs in the cluster and a new headlight switchnan still no luck all so replaced the fuse any idea what to check next?
  18. Thanks, no more flinstone truck.
  19. Trying to get floor pans on the cheap. The salvage yard guy in town is a friend an doesnt charge me much. But he only has cherokees in the yard. I could only find a good pan in a 96 he had will it work, an can the carpet be swaped seemed in decent shape. Maybe if i cut the carpet where the cab ends on the truck?
  20. I just got my 88 going again yester day. Marvles mystery is what i used. All the rubber o rings on the injectors, radator hoses, an fuel pump where roted an the fuel rail need an o ring too. O an fuel lines that where high pressure got tossed for the hell of it. Radiator flush an new thermostat was rusted shut. She sat for 4 years or so though.
  21. Nope just took the lock out. Its had this problem befor, I took the busted cylender out. I didnt change the column. So I'm guessing its on down the line of detective work. Learning as I go.
  22. Ten 4 wired her up key works / comes out but now the dang thing doesnt shut off when the key is out unless clutch kill it
  23. After more reading. It looks like theres a linkage from the old jeep, it came from I'm guessing its an automatic wigit is there a conversion i got a 5 speed peugeot. Or do I just have to leave the dash apart to push it back in?
  24. Put a new ignition cylender in the 88 manche. After install and prior the key wouldnt come out. After i took the dash off there was a gray knob that poped out of the buttom of the column. So i pushed it in an the key comes out. Turn the key it pops back out, an the key won't come out. Is there some thing I'm missing? The column was out of a cherokee with tilt an works fine other then this knob / key problem.
  25. Usen my phone. Kinda a pain, to do.
