Jtrux Posted March 27, 2016 Share Posted March 27, 2016 My project is coming along but still has some issues. One is that when idling or accelerating from a stop, as soon as you crack the throttle and manifold vacuum drops, it really stumbles. Once the vacuum catches up a little, it seems to be okay. Taking off from a stop seems to exacerbate the issue. Any thoughts? Link to comment Share on other sites More sharing options...
benjy_26 Posted March 27, 2016 Share Posted March 27, 2016 My 2.5 was doing that til I installed new gaskets in my TBI unit, replaced my intake/exhaust manifold gasket, and plugged my egr. I basically took care of a bunch of leaks in my engine and it went away. Link to comment Share on other sites More sharing options...
Jtrux Posted March 27, 2016 Author Share Posted March 27, 2016 I think that my EGR is stuck open. I do not have it hooked it. Here's another reason I think it is stuck open. When I cover the throttle body up with a rag, there is no change at all. It must be drawing air through the EGR. Link to comment Share on other sites More sharing options...
benjy_26 Posted March 27, 2016 Share Posted March 27, 2016 Yep. Sounds like you have an intake leak somewhere. Link to comment Share on other sites More sharing options...
spyder152 Posted April 14, 2016 Share Posted April 14, 2016 Mine is doing the same thing, but only when it's cold and the idle is below 1000, once it's warm, runs great, i'll check for leaks Link to comment Share on other sites More sharing options...
cruiser54 Posted April 14, 2016 Share Posted April 14, 2016 My project is coming along but still has some issues. One is that when idling or accelerating from a stop, as soon as you crack the throttle and manifold vacuum drops, it really stumbles. Once the vacuum catches up a little, it seems to be okay. Taking off from a stop seems to exacerbate the issue. Any thoughts? What year and engine? Link to comment Share on other sites More sharing options...
